Simulation problem which using user subroutine
Hello.
I'm a ABAQUS user. I have some problem about my analysis. So I ask about my simulation.
First, my PC system is below.
- ABAQUS 6.12-1
- Intel fortran compiler
- visual studio 2008
My simulation and user subroutine is below.
- Soil step, considering permeability with heat transfer
- UMAT
- UMATHT
- USDFLD
I combine the all subroutine in one file. So analysis was successfully finish every time.
But here is the problem.
I use the USDFLD for change the permeability following the STATEV(2) value.
But permeability didn't change during analysis.
I check the Field variable value (FV1) and FV1 change following the STATEV(2) value.
In the analysis, only first permeability(9.741e-08, 0.8, 1) was applied during all analysis.
It was compared using none USDFLD used analysis. (only first permeability value was used)
When I change the first permeability value(9.741e-08, 0.8, 1), then result was changed.
And if I change the second permeability value(4.8705e-08, 0.8, 2), then result was not changed.
Below is the my analysis data part.
I'll wait your's professional many comment.
Thank you.
Materials.
*Permeability, Type=iso, dependencies = 1, specific=10000
9.741e-08, 0.8, 1
4.8705e-08, 0.8, 2
9.741e-07, 0.8, 3
3.6042e-06, 0.8, 4
*User Defined Field
Subroutine of USDFLD
subroutine usdfld(field,statev,pnewdt,direct,t,celent,time,dtime,
1 cmname,orname,nfield,nstatv,noel,npt,layer,kspt,kstep,kinc,
2 ndi,nshr,coord,jmac,jmatyp,matlayo,laccfla)
c
include 'aba_param.inc'
c
character*80 cmname,orname
character*8 flgray(15)
dimension field(nfield),statev(nstatv),direct(3,3),t(3,3),time(2)
dimension array(15),jarray(15),jmac(*),jmatyp(*),coord(*)
if (KSTEP == 1) THEN
Field(1)=1.D0
else if (KSTEP == 2) THEN
If (STATEV(2) .LE. 20) Then
Field(1)=1.D0
else if (STATEV(2) .GT. 20 .and. STATEV(2) .LE. 1000) THEN
Field(1)=2.D0
else if (STATEV(2) .GT. 1000 .and. STATEV(2) .LE. 1200) THEN
Field(1)=3.D0
else if (STATEV(2) .GT. 1200) THEN
Field(1)=4.D0
end if
end if
return
end
