Help in Journal Error
Hi
In this journal (that I revised from internet one) I get error in line 31
line 31 ==> attrInfo = body_object.GetUserAttribute("test",NXObject.AttributeType.String,-1)
Using NX8.5
What's wrong here
My goal is to read the body attribute (Title = Value) for a given title gets its value
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
Imports NXOpen.Utilities
Imports NXOpen.UF
Module report_attrs_by_title_and_type
Dim s As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Sub Main()
Dim body As NXOpen.Tag
While select_a_body(body) = Selection.Response.Ok
Dim loopVar As Integer = 0
Dim body_object As NXObject = CType(NXObjectManager.Get(body), NXObject)
MsgBox("Body Object:" & body_object.ToString())
Dim attrInfo As NXObject.AttributeInformation
Try
ufs.Ui.OpenListingWindow()
ufs.Ui.WriteListingWindow("Attribute Title: " & attrInfo.Title & vbCrLf)
ufs.Ui.WriteListingWindow("Attribute Type: " & attrInfo.Type.ToString & vbCrLf)
ufs.Ui.WriteListingWindow("Attribute StringValue: " & attrInfo.StringValue & vbCrLf)
Catch ex As Exception
MsgBox(ex.ToString(), MsgBoxStyle.Critical)
End Try
End While
End Sub
Function select_a_body(ByRef body As NXOpen.Tag) As Selection.Response
Dim message As String
Dim title As String = "Select a body"
Dim scope As Integer = UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY
Dim response As Integer
Dim obj As NXOpen.Tag
Dim view As NXOpen.Tag
Dim cursor(2) As Double
Dim ip As UFUi.SelInitFnT = AddressOf mask_for_bodies
ufs.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
Try
ufs.Ui.SelectWithSingleDialog(message, title, scope, ip, _
Nothing, response, body, cursor, view)
Finally
ufs.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
End Try
'ufs.Disp.SetHighlight(body, 0)
If response <> UFConstants.UF_UI_OBJECT_SELECTED And _
response <> UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME Then
Return Selection.Response.Cancel
Else
Return Selection.Response.Ok
End If
End Function
Function mask_for_bodies(ByVal select_ As IntPtr, _
ByVal userdata As IntPtr) As Integer
Dim num_triples As Integer = 1
Dim mask_triples(0) As UFUi.Mask
mask_triples(0).object_type = UFConstants.UF_solid_type
mask_triples(0).object_subtype = UFConstants.UF_solid_body_subtype
mask_triples(0).solid_type = UFConstants.UF_UI_SEL_FEATURE_BODY
ufs.Ui.SetSelMask(select_, _
UFUi.SelMaskAction.SelMaskClearAndEnableSpecific, _
num_triples, mask_triples)
Return UFConstants.UF_UI_SEL_SUCCESS
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
THANKS in advanced
RE: Help in Journal Error
Quote (a984928)
What does the error message say?
www.nxjournaling.com
The error message is telling us that the body that was selected does not have a string attribute named "test". Are you sure that the attribute was applied to the body and not a feature or the part itself?
The part contain an extrude of a sketch rectangle
that I right click on it and in the opened dialog on attribute tab
I set Title to "test" and a string type value I set it to "t3"
so I have Title = "test" and its value = "t3"
and for select a body I selected the extruded rectangle
and that give this err
Thank you again
Double check to see that you have assigned the attribute to the solid body itself and not the extrude feature. Go to Edit -> properties, change your selection filter to solid body and check to see if the attribute exists. Repeat with your selection filter set to "feature" and see if the attribute exists there.
You are right
I set the attribute with filter solid body and that works
thank you very much
Cowski if I want to do that for all the atributtes of that solid body
can you help what functions to use
Thank you a lot
To get all the attributes of the body, you can use the .GetUserAttributes method; this will return an array of NXObject.AttributeInformation structures that you can query.
I get it
it is near to me and I didn't see it
Thank you for this whole help
Hi cowski
If you see this
My finished journal works very well but I need it in DLL, but when I compile I get this errors
using nx8.5 and this compiling command
C:\WINDOWS\Microsoft.NET\Framework\v3.5\vbc /libpath:C:\hvv\_VBC\managed /t:library /r:NXOpen.dll /r:NXOpen.Utilities.dll /r:NXOpen.UF.dll /r:NXOpenUI.dll report_body_attribute_for_title_ref_des_value_13.vb > o3.txt
o3.txt output
Microsoft (R) Visual Basic Compiler version 9.0.30729.5420
Copyright (c) Microsoft Corporation. All rights reserved.
C:\haviv\dev\__UniGraphics_VB__\_VBC\report_body_attribute_for_title_ref_des_value_13.vb(32) : error BC30456: 'GetUserAttributes' is not a member of 'NXOpen.NXObject'.
attrInfo = body_object.GetUserAttributes()
C:\haviv\dev\__UniGraphics_VB__\_VBC\report_body_attribute_for_title_ref_des_value_13.vb(40) : error BC30456: 'StringValue' is not a member of 'NXOpen.NXObject.AttributeInformation'.
def_res_value = attrInfo(loopVar).StringValue
C:\haviv\dev\__UniGraphics_VB__\_VBC\report_body_attribute_for_title_ref_des_value_13.vb(45) : error BC30456: 'StringValue' is not a member of 'NXOpen.NXObject.AttributeInformation'.
geom_name_value = attrInfo(loopVar).StringValue
C:\haviv\dev\__UniGraphics_VB__\_VBC\report_body_attribute_for_title_ref_des_value_13.vb(76) : warning BC42024: Unused local variable: 'obj'.
C:\haviv\dev\__UniGraphics_VB__\_VBC\report_body_attribute_for_title_ref_des_value_13.vb(84) : warning BC42104: Variable 'message' is used before it has been assigned a value. A null reference exception could result at runtime.
journal code
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module report_body_attribute_for_title_ref_des_value
Dim theUI As UI = UI.GetUI()
Sub Main()
Dim def_res_title As String
Dim geom_name_title As String
Dim def_res_value As String
Dim geom_name_value As String
Dim attrInfo() As NXObject.AttributeInformation
Try
Dim cntr As Integer = attrInfo.Length - 1
Do While loopVar <= cntr
If attrInfo(loopVar).Title = "REF_DES" Then
def_res_title = attrInfo(loopVar).Title
End If
If attrInfo(loopVar).Title = "GEOM_NAME" Then
geom_name_title = attrInfo(loopVar).Title
End If
loopVar = loopVar + 1
Loop
theUI.NXMessageBox.Show("logo name" , _
NXMessageBox.DialogType.Information, _
def_res_title & " = " & def_res_value & vbCrLf _
& vbCrLf & geom_name_title & " = " & geom_name_value)
def_res_value = ""
geom_name_value = ""
def_res_title = ""
geom_name_title = ""
End Try
End While
End Sub
Try
Finally
End Try
'ufs.Disp.SetHighlight(body, 0) this line here
'give error so I moved it to main sub
Else
End If
End Function
End Function
End Function
End Module
I see a lot about this error in the internet
but I found nothing that can help
Thank you in advanced
Do you have any older versions of NX installed?
If so, make sure that the compiler is referencing the NX 8.5 dll files and not the older versions.
Hi Cowski
Without your help I'll never never come to it
The internet not helped me you do
Thank you very very much
