Dry stand pipe
Dry stand pipe
Please help!!!!
1.Location of Siamese base on the NFPA?
2.Is it ok if the dry standpipe is only one for 12th floor building?
RE: Dry stand pipe
http://albanesmolina.wix.com/home
RE: Dry stand pipe
As stated, FDC shall be accessible to the FD. You also want it located within a certain distance from the nearest hydrant. That could be 150-300' depending on jurisdiction requirements.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
RE: Dry stand pipe
the old design was stated below:
1. on ground floor has AFSS inlet,dry stand pipe inlet, and testing for fire department inlet.
2. on roof deck has siamese twin output.
My question is what is the standard on the NFPA?
RE: Dry stand pipe
Typically we see them in every exit stair.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
RE: Dry stand pipe
RE: Dry stand pipe
Travis Mack
MFP Design, LLC
www.mfpdesign.com
