Heat exchanger design for 500 degC - fittings
Got an application that currently uses ASTM A403 WP304L fittings and I'm looking at using WP316L. The fittings are part of a heat exchanger and will be exposed to temperatures approx. 500 degC. Are there any concerns regarding the change in material, such as hardness and longevity?
Cheers
Digs
RE: Heat exchanger design for 500 degC - fittings
Is this heat exchanger ASME code stamped? The reason I ask is that the A 403 material is not used for ASME pressure fittings.
No exchanger is stamper AS1228
Check with the Australian construction code for advice on acceptable materials.
Hello metengr - I am a little surprised with your statement
[quote metengr][ The reason I ask is that the A 403 material is not used for ASME pressure fittings./quote]
SA 403 fittings are very common to be used in ASME Vessels and Heat exchanges.
Why would say that they are not allowed?
Kindly clarify your position.
D2HANDLE
Can you show me where A 403 material specification is specifically referenced within a material group in ASME B16.5 or 34?
metengr,
I was talking about the wrought butt welded fittings such as Elbows, tees, Reducers etc. in accordance with ASME B16.9.
D2HANDLE
I believe if you review this standard the list of material groupings refers back to material groupings in B16.34.
I am confused again......
B16.34 is the standard for Valves — Flanged, Threaded, and Welding End.
Are you sure you are referrring to this B 16.34?
Also, the materials allowed for wrought fittings are all mentioned in Par. 5 of the standard, and I cannot find any reference to B 16.34 for the material grouping.
D2HANDLE
I was able to retrieve my copy of ASME B16.9, and A 403 is indeed listed. My apologies. I was thinking of B16.5.
If it's the 'real' L-grade of 316 youre dealing with (and not the straight or the dual certified one), then 500°C may be a concern.
ASME II-D, although probably not applicable to your situation, lists L-grade up to a max of 454°C. Same counts for B16.5 (but then for 304L forgings).
It's in there for a reason, even if youre not working to any ASME standard, consider those reasons.
Thanks guys, much appreciated.
