Air distribution through an open duct
I have an architect who is extremely concerned with aesthetics and wants us to provide an open slot duct connection in lieu of a bar type linear diffuser for air distribution, I am well aware of a lack of distribution with this scheme and have informed the architect of the problems that may occur with dumping and stratification of the air. I don't want to agree with something that I know will end up being a source of complaints, in order to somewhat control this I was considering the installation of Young regulators for air balancing and some kind of distribution, any comments would be appreciated
RE: Air distribution through an open duct
B.E.
You are judged not by what you know, but by what you can do.
When comes to this kind of situation, I would propose frameless slot diffuser for the architect to consider. It is a standard product with control damper, see image attached. Usually, architect just does not want to see the frame of the diffuser. I managed to convince the architect for my projects.
.TT pocketengineer SD
...creating a mobile design environment
https://pocketengineer2.sharepoint.com/Pages/OverV...
Don't be afraid to explore options beyond different diffusers, consider duct location or even the type of duct. Ductsox is a good alternative.
Flow and pressure need to be controlled very well at duct entrance. Some obstacles should not exist in space.
And, even more important, you need to charge architect for extra effort in engineering. So, it is possible, but you have to charge it!
