Welding schedule
Welding schedule
Dear experts,
I wonder if there is a guidance for how many passes required to weld plate to plate.
For example A283C bottom plate 10 mm to be lap welded to 10 mm bottom plate. Root pass would be 2.4 mm EXXXXX + filler 3.2 mm EXXXX + capping 2.4 mm Exxxx etc.
Maybe it is depend on WPS / PQR ?
Syah
Syah
RE: Welding schedule
Then you can consider the WPS(s) to be used on the lap joint.
Hope this helps-
