Merging lines in fillet?
Shown above is the fillet of two surfaces. There's a small surface in between the two curves designated by the red arrows. How can I remove that small surface by merging the two curves?
RE: Merging lines in fillet?
If the surface is G1 continuous to the surfaces near it then you might be able to use "Sew Surface" function in GSD workbench - or try a join.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
