Can someone help me with my Planetary Gear Set.
I do not understand why this is not meshing correctly.
CAD Link
I calculated:
Gear Ratio: Ring Held Stationary
Would Appreciate the Help!!
Ethan
CAD Link
I calculated:
Sun Gear: 12 Teeth
Planet Gear: 9 Teeth
Ring Gear: 30 Teeth
Between Sun and Planet: 12/9
Between Sun and Carrier: 12/42
Ethan
RE: Can someone help me with my Planetary Gear Set.
For each clock-wise turn of the carrier, the planet will make 1 turn clock-wise + 30/9 turns counter-clockwise.
With regards to the latter, your epicyclic with a 12T sun, 9T planet and 30T ring requires a fair bit of tweaking to simply mesh without interference. Getting the gearset to mesh "smoothly" will be a far more difficult task.
