Problems combining Macro with Journal.
Hello, I would like to combine a macro with a Journal.
I’ve a macro and now I created a journal to export drawings to PDF, I need that this journal first call and execute the macro and then exporting to PDF.
The problem is the macro doesn’t execute until the journals ends.
What can I do to make the macro run before the rest of the Journal?
Thanks in advance.
Thanks in advance.
RE: Problems combining Macro with Journal.
www.nxjournaling.com
My only solution is to call this macro from the journal but occur the problem that I previously commented.
Can you think of some way to make it work properly?
Thank you very much for your help.
thread561-367518: Run Macro through NX API
