Different shapes sheet piles with similar section modulus share the same performance in Bending?
Hi All,
Have a quick question. I am working on a sheet pile wall design. Client has SPU-IIIw sheet pile while the software I am using does not have this material in its property library.
However, I can find an equivalent sheet pile which has a property close to but lower than what the client has. Specifically I am using Larsen L604 for my design. Will the two sheet piles
perform the same in bending and deflection assuming both have the same Section Modulus property?
http://files.engineering.com/getfile.aspx?folder=7...
Thanks.
Alex
I have attached a picture of the property comparison between the two sheet piles.
Thanks.
Alex
RE: Different shapes sheet piles with similar section modulus share the same performance in Bending?
Also remember to use the correct yield stress for the sheet pile, in your analysis.
DaveAtkins
Noted and thank you on the response.
Alex
