NX9 - Import Assembly into Team Center
I do a lot of importing and exporting files lately. Every time I click on one, the dialogue box pops up and I have to go through and change several settings. Is there a way to change the settings somewhere so they are defaults?
I was looking in Customer Defaults but could not find these settings anywhere. Do they exist?
RE: NX9 - Import Assembly into Team Center
When you do the first import and completed your settings, go to Log Files Tab.
Specify the output logfile location. You can now either import your assembly or make a dry run.
The utility will create a logfile which you can use with the "Load and Apply Existing Log File". It will contain all your settings.
Although the logfile itself will show the parts you have used for earlier import action it will not select them for your next ones. You will have to select a new assembly for import.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
