C/P from one drawing to another (background view to background view)
Hello, i need some help here.
I am trying to create macro to paste everything from background view from template drawing to background view of active drawing sheet. Code needs to choose right sheet from template drawing and it does so by creating string from paper size and orientation on active sheet and some selection from combobox. this is pretty simple stuff. now my code opens template and choses right sheet and copies everything from background view but it fails on line where i need to add active sheets background view to selection (see code below). Error message i get is "Object doesnt support this property or method" and i really don't understand why. Also it gives same error if i try to add sheet to selection instead of view. After it pastes it should close template file but that should be simple enough. All objects in code that start with "t" are template ones and "o" are active sheet ones. I am using VBA. Catia V5R21
Thank you for your time
CODE --> VBA
Private Sub btnImport_Click()
    Dim oDocs As Documents
    Set oDocs = CATIA.Documents
    Dim oDoc As DrawingDocument
    Set oDoc = CATIA.ActiveDocument
    Dim oSel As Selection
    Set oSel = oDoc.Selection
    Dim oSheets As DrawingSheets
    Set oSheets = oDoc.Sheets
    Dim oSheet As DrawingSheet
    Set oSheet = oSheets.ActiveSheet
    Dim oViews As DrawingViews
    Set oViews = oSheet.Views
    Dim obckView As DrawingView
    Dim ori As String
    Dim size As String
    Dim lang As String
    Dim SastName As String
    Select Case oSheet.Orientation
        Case 1
            ori = "L"
        Case 0
            ori = "P"
    End Select
    Select Case oSheet.PaperSize
        Case 2
            size = "A0"
        Case 3
            size = "A1"
        Case 4
            size = "A2"
        Case 5
            size = "A3"
        Case 6
            size = "A4"
    End Select
    Select Case Me.obLang1.Value
        Case True
            lang = "HR"
        Case False
            lang = "EN"
    End Select
    SastName = size & ori & "-" & lang & "-" & Me.cbSastavnica.Value
    Dim tDoc As DrawingDocument
    Set tDoc = oDocs.Open("E:\Scripts\Sastavnice.CATDrawing")
    Dim tSheets As DrawingSheets
    Set tSheets = tDoc.Sheets
    Dim tSheet As DrawingSheet
    Set tSheet = tSheets.Item(SastName)
    Dim tViews As DrawingViews
    Set tViews = tSheet.Views
    Dim tbckView As DrawingView
    Set tbckView = tViews.Item(2)
    Dim tSel As Selection
    Set tSel = tDoc.Selection
    tSel.Clear
    Dim tGeoElements As GeometricElements
    Set tGeoElements = tbckView.GeometricElements
    For Each tElement In tGeoElements
        tSel.Add (tElement)
    Next
    For Each tText In tbckView.Texts
        tSel.Add (tText)
    Next
    tSel.Copy
    oDoc.Activate
    Set obckView = oDoc.Sheets.ActiveSheet.Views.Item(2)
    oSel.Clear
    oSel.Add (obckView)  **************** BREAKS HERE ******************
    oSel.Paste
End Sub
RE: C/P from one drawing to another (background view to background view)
i got solution from another forum:
"It looks like you probably just need to change:
oSel.Add (obckView)
to either Call oSel.Add (obckView)
or oSel.Add obckView
in VBA subroutine calls need to be prefixed with "Call" if you use parentheses around the arguments, or you not if you do not include parentheses.
You will also need to change the calls adding to the selection above it in the same way as they will throw the same error when you have elements or texts to copy. "
Hi
Well, searching forum should be first option for everyone... check this thread and somewhere at the end there is a macro which can be adapted to your needs (if is necessary). There are also few several threads related to background of the catdrawings.
Anyway, good that you solved your problem.
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
Ferdo thank you for reply.
i did search the forum and my code didn't work for some reasons that are still strange for me because i did what that guy from another forum proposed (only remove parentheses) and it worked. However, i did not remove parentheses from lines where texts and lines from background were added to selection. So, in a way, 2 different ways of calling subroutines were used and i don't understand why is this.
