Conditional sketch geometry using logic
I want to add some logic to a model so that part of a sketch has either a line or an arc drawn dependent on the value of a parameter. So if 'Parameter' > 1 then draw as a line else draw as an arc. Either the arc or line need a tangency condition at one end and a coincident condition at the other.
Alternatively I could have two copies of the sketch, one with an arc, one with a line and have catia activate and use as the input for the following revolute operation based upon the parameter.
I've come across some examples of using the KWA rules and fog laws to affect values based upon this type of logic but have not found if it's possible to effect what type of geometry is drawn in this way. Can this be done?
RE: Conditional sketch geometry using logic
you have to create both entities and use logic to activate / deactivate them
Eric N.
Thanks, I wasn't quite sure how to do that either but I've figured it out.
You could use a KWA reaction that executes only when the user changes 'Parameter' and then the code activates/deactivates the line/arc depending on the value.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
