(Shell) element size vs. its thickness?
To all
Before I "dive" back into my book on the FE method I thought I ask the question
Assuming a model made of 2D elements (shell) with a thickness 't' (let's say t=5mm) and the surface of interest being much larger that 't' (assumes a square 1000mmx10000mm) if one keeps refining the elements and end up with a very small size (let's say 0.25mm or even smaller if you want) is there a point when one "violates" the theoretical assumptions of a shell element? I am thinking about the fact that the element is much thicker than its size
Any thoughts?
Any thoughts?
RE: (Shell) element size vs. its thickness?
be aware of out-of-plane deflections, typical 2D shell elements work like a plate and are quickly inaccurate if there are out-of-plane displacements.
For SOL101, if you read through Nastran books, you will come up with a 3t (t=thickness) ideal element size there. But if you work on designs with complex surfaces, you will come to see that 3t is actually not the best size that suits all your needs. After sometime, the term "mesh convergence" will strike from another research. So, all hand in hand really comes down to your model and assumptions (always).
With your beam like plate structure, it would probably undergo buckling/linear static/modal analysis all at once. So, a mesh size of your element thicknesses would do. If you would happen to check the stresses around your fastener regions "in detail", then you would need to create a "flexible fastener modeling" & nice finemesh regions for your plate modeling for those fastener surroundings.
As long as you are SOL101 (or other linear solvers), then your "finemeshed fastener area and element size equal to the thickness" should be adequate for that plate. If your stresses are still high, you have a weird mechanism going on there which is either stiffening your structure infinitely, or as less of a chance: some of your loadpaths are broken. But from your other post, I don't think you would be at a level to face this as of yet. Just keep in the back of your mind. Broken loadpaths are weird and cause peaks out of nowhere. Have seen some examples of them in other people's models but never had one myself. So, not everybody causes them really. Just some people.
Spaceship!!
Aerospace Engineer, M.Sc. / Aircraft Stress Engineer
http://members.ozemail.com.au/~comecau/perforated_...
Avoiding this is one of the reasons for starting with a coarse mesh, refining, then checking for convergence. That process is essentially hunting for the largest size that can accurately represent the "infinitesimal" used in analytic calculations. It avoids problems like incredibly fine meshes when they don't provide much additional accuracy.
