Safety/Relief Valve Discharge Piping
Other than structural, what criteria should be used in designing Safety/Relief Valve Discharge piping? For example:
Flow velocity, pressure drop, quality (if two phase),etc.
RE: Safety/Relief Valve Discharge Piping
Per ISO, only the term Safety Valve is used regardless of application or design.
Weep holes to drain accumulated liquids.
I'm sure API 521 lists these.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
From a structural perspective, don't overlook acoustic induced vibration (AIV) risks which are associated with tailpipes connected to a collection header. Use the simple equation in API 521 to calc the sound power level. This sound power level is a screening criterion for assessing whether there's a risk of AIV failure at the point where the tailpipe connects to the header. Tailpipes < 10" diameter are potentially exposed to this failure mechanism.
API 520 Part 2 breaks down the guidelines for the design of proper discharge line design.
There is far too much information there for me to adequately break it down in a forum post. However, after you review the document you can feel free to come back and ask clarifying questions.
