Airflow through venturi
We wish to modify a venturi/eductor to make sure that we are getting the best vacuum possible when a compressed air motive is applied to it. I was hoping to find someone or company that is knowledgeable in this type of equations?
RE: Airflow through venturi
If it's not enough, get a bigger compressor.
Or, better, get a water-driven eductor and use water as your motive fluid; it's much less noisy than air.
This one should work fairly well on city water, for not a lot of money:
http://www.amazon.com/Nickel-Plated-Hydro-Aspirato...
A search on eductors, venturi pumps, and related phrases will bring up half a dozen well known companies that produce this stuff to fairly high precision, with predictable performance. The market is not large, and you need to cut away a lot of material from a billet to make the parts, so they can be fairly expensive.
Mike Halloran
Pembroke Pines, FL, USA
http://www.eng-tips.com/viewthread.cfm?qid=231142
A quick search also brings up:
Penberthy
Jacoby Tarbox
Alfa Laval
Surely one of them, or a friend or emeritus thereof, can be persuaded to help.
Just pick up the phone, and social-engineer your way to the real engineers.
ISTR that I found a set of equations in one of those thick ME Handbooks, which are all in storage right now, and tried to work through them. Eventually I just scaled an illustration in a catalog, and tried to sort of duplicate that.
I made one, a long time ago, from standard tubing fittings, that worked well enough to atomize some solvent and spray it on something I was trying to degrease.
I've made another from pipe fittings with a laser-cut core, that was intended to suck condensed water out of big exhaust pipes without being burned up by the exhaust gas. It worked well enough to do that, and to help drain a flooded floor.
I.e., it's fairly easy to make an eductor that works well enough to amaze people who have never seen one work, but predicting and adjusting and optimizing its performance takes some experience that I don't have.
Good luck.
Mike Halloran
Suggest searching NACA tech report server http://ntrs.nasa.gov/search.jsp using terms 'air ejector'
NOTE: the term 'air inductor' will not work... the term 'inductor' is interpreted as an electrical component/function.
The jet I work on has a 'air mover system' [which is actually an air ejector] which is placed downstream of a heat exchanger [HE]. ON THE GROUND [no airspeed], pressurized air is pumped thru the many ejector nozzles inducing air flow from the inlet, thru the HE, the out the exhaust port [airflow is essentially 'pulled' thru the system]. When airborne, this 'air mover system' is turned-off and dynamic air-flow is brought-in thru the NACA inlet, up-stream of the HE... which then pushes air thru the same HE duct to the [same] exhaust port [around/thru the non-operating air-mover nozzles].
Regards, Wil Taylor
o Trust - But Verify!
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can b
there seems to be lots of stuff ... some have to be able to help you ...
There is a body of knowledge in this trade for air operated vacuum venturis, as a component in air conveying systems.
I have used these devices in the aircraft trade for pickup of spent plastic paint stripping media from stripping booth floors.
I am posting a link to one manufacturer, this may lead you to others. I get the idea that you really don't want engineering help, that you just want a company to do the job for you.
B.E.
You are judged not by what you know, but by what you can do.
