DC Stray Voltage
DC Stray Voltage
I am interested in gaining some knowledge on DC stray voltage. I am involved in a project where the question has arisen about the possibility of DC stray currents. The system consists of anodes and cathodes in pvc wells and the DC can be up to 100 volts. There is also a similar setup with AC voltages up to 560 V but everything is grounded so that should be ok. The DC system is not grounded so is it possible to have stray currents.
Thank you
Thank you
RE: DC Stray Voltage
Keith Cress
If there's dirt on the substrate, stray currents will increase. I think that is fairly obvious.
But, there are triboelectric phenomena and there is influence from nearby fields that can change voltage/charge. Is that what you are thinking about? The early CMOS circuits were known to be sensitive to external charges and all it took to destroy a device was to pick it up from an insulating surface (that's why the warning symbol is a hand picking something up).
Gunnar Englund
www.gke.org
To mitigate the stray voltage, some utility oversize the neutral to reduce the impedance and reduce the earth return current.
I do not remember to see any report of stray voltage in DC electrical system. I hope you are not confusing with stray voltage found in Washington DC. See more detail in the enclosed link (ignore the first part of the video).
. http://www.nbcwashington.com/news/local/282633341....
Bill
"Why not the best?"
Jimmy Carter
