Hydraulic DC generator Control
I have a 20 kw hydraulic DC generator used to power a magnet. To work properly, it needs to give me 230VDC, consistently. I need a way to get this working. I taught about a proportionnal valve or a servo valve to control de hydraulic motor.
RE: Hydraulic DC generator Control
Keith Cress
IF those two assumptions are correct then the proper solution involves (1) a transformer to change the incoming AC power from the grid to whatever the required voltage is, (2) a rectifier to convert that AC to DC, (3) toss all the hydraulics in the bin because you don't need it any more.
Converting energy from one source to another is inefficient, and conventional industrial hydraulic pumps and hydraulic motors are particularly so. And keeping it all electrical means no leaks, no mess, less noise, less stuff to break down.
Now explain to me why you can't do it the way I just explained.
