Nubbin on a Body Flange
What drives the requirement for a Nubbin on a Heat Exchanger Shell Flange?
RE: Nubbin on a Body Flange
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
2) Cost. Per Appendix 2 of ASME Section VIII Div. 1, machining a nubbin onto the flange gasket surface usually reduces the required bolting area so that fewer (or smaller diameter) bolts can be used.
Personally I'd recommend against using nubbins if you have a choice.
-Christine
