DIN standard for fastener
Hi there,
I looking for DIN standard handbook for fasteners product. Can anybody help me to give me reference for find this DIN standards.
Any input will be greatly appreciated.
Thanks.
NOOR A
RE: DIN standard for fastener
DIN Handbook 10 Fasteners 1 - Dimensional standards for bolts, screws and studs – National Standards
DIN Handbook 55 Fasteners 3 - Standards for technical delivery conditions for bolts, screws, nuts
DIN Handbook 140 Fasteners 4 - Basic and dimensional standards for nuts
DIN Handbook 193 Fasteners 5 - Basic standards
DIN Handbook 362 Fasteners 6 - Dimensional standards for bolts and screws – European Standards
A word of caution, that may or may not be applicable.
I discovered several years ago that the heads of typical 'American' metric pan heads may be taller than rest of the world metric pan heads.
thread725-224430: Head dimensions for North American pattern M2.6 panhead
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
i'm not familiar with this standard,usually i refer to JIS standard,for making a product i need reference.
and i dont know where i buy or download DIN standard.please share me if you have source
thanks a lot,
Start at Maryland Metrics, as already suggested.
Last time I looked, which was a long time ago, there wasn't a DIN standard for pan head screws, but there were standards for somewhat similar but not so tall 'cheese head' screws.
When the 'Merican car manufacturers started converting to metric, they did pretty much as they pleased, standardizing their own pan head screws with metric threads. ... which they could do, because they buy so many of them.
Mike Halloran
Pembroke Pines, FL, USA
on Maryland Metrics only dimension,not explain a mechanical properties
www.DIN.de/en
NOTE : probably DIN standards about fasterners are superseded by EN Standards. You should know the DIN one so to check if is still ruling or not
noted and thanks,
