API 6A Block Fittings
Is there a particular API spec that specifies 15,000 psi block fitting dimensions? Say a block 90 or tee?
I cannot find any standard dimensions in API 6A and am under the assumption that these can only be rated after analysis and testing. Is this correct?
Are there any "published" sizes for high pressure block fittings? Thanks!
RE: API 6A Block Fittings
