Building a Metal Insert for System Retaining Wall
First post here. I am trying to build an insert for concrete system retaining wall systems that is made from metal. I am essentially trying to develop a sleeve that has the least thickness possible while still maintaining ASTM standards of 2,500 PSI, and < 10% absorption. The dimensions would match that of your standard block, 10" deep, 10" wide, and 6" tall.
Can anyone suggest a type of metal which can bear this much pressure and be resistant to oxidation?
Thank you!
Thank you!
RE: Building a Metal Insert for System Retaining Wall
Much appreciated.
