C Channel Connections
Good afternoon Gentleman and Gentleladies
I am currently trying to make an endplate connection for C Channel in a cantilevered situation. Should one use AISC design guide 4 for these parameters? I have a small moment, 24 kip-in with about 1 kip of shear.
RE: C Channel Connections
Don't forget to account for the fact that the shear center of the channel will be behind the web of the channel, and so the forces on your endplate bolts won't be uniform, as they would for a symmetrical wide-flange beam's endplate.
Dave
Thaidavid
