Crotch Factor for tee
Dear all,
It is mentioned in the ASME 16.9 that different tees from different manufacturer can have different dimensions. I am trying to get a standard value or crotch Factor (CF=T_Crotch/T_Nominal). VES tool is taking 1.25 crotch factor on default. I have seen on few manufacturer website crotch factor is 1.3.
Does any one of you have information about the min. crotch requirement.
RE: Crotch Factor for tee
Thanks for your reply but in that case what would be the rejection criteria for the tee fittings?
