15% and 28% Hcl Acid
Flow medium: 15% and 28% Hcl Acid
Working pressure: 10000 psi
Flow rate: 60 bbl/min
Working Temp: Max 50 deg C, Min -10 Deg C
What would be the suitable piping material and MOC for valves?
RE: 15% and 28% Hcl Acid
http://steelfinder.outokumpu.com/corrosion/?_ga=1....
and
https://www.nickelinstitute.org/en/TechnicalLitera...
What you will learn that there is no commonly available metal that will work. You are looking at alloys like B-2 and B-3. the better bet is lined FRP. This is common for this service.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Steve, yes its for well stimulation fluid application
Is there really lined FRP that is good to 10000psi?
(genuinely curious - I've used it up to maybe 200-300psi and that is already awfully thick. I can't imagine what a 10000psi rated FRP pipe would look like.)
Steve Jones
Most of these treatment packages are designed with a specific MOC in mind. And they should be able to tell you want that is and what the expected life is (usually fairly short).
