NX laminates can not find the ply thickness tolerance dialog box.
I am trying to model an example for fill laminate. The distance between the two faces varies.
NX adapts the size of the plies to fill up the space. But I only want to vary the core thickness
not the outside plies which should from carbon.
It should be possible, I found it in the manual, but I can not right mouse button on a ply node
to get Edit Ply Thickness Tolerance.
I am on NX 10.0.3.5 no MP's W8.1
I hope I do not overlook anything.
Can someone point me in the right direction?
I attach a PDF where it is described with figures.
Thanks for your time.
Olaf
Olaf
