Aluminum Chlorohydrate scaling up feed lines.
We feed ACH as our coagulant and it seems to be scaling up our feed lines. The substance is hard, brittle, flaky red substance, has anyone else had this problem?
RE: Aluminum Chlorohydrate scaling up feed lines.
Is this a new problem?
Have you changed chemicals or has there been a major change in water quality or source?
Is the red substance water soluble, acid soluble or neither?
Are you treating drinking water or something else?
Are you feeding the ACH with another chemical?
Can you feed the ACH directly into the dose point rather than using a carry water system?
Ashtree
"Any water can be made potable if you filter it through enough money"
Is it a powder , liquid or some sort of proprietary blend?
Ashtree
