GPS receiver recommendations
I'm looking for a GPS receiver that I can Ethernet into a router and essentially just log in and get the coordinates, perhaps from a served webpage.
Google, Amazon and Ebay hain't learned me no thing about a simple product like this.
Keith Cress
RE: GPS receiver recommendations
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
There are probably a few still around.
The dongle talks to the app over USB, I think using plain text.
So I'm guessing you could hook it to an Arduino or something similar and set up your own webpage or whatever you like.
I thought it was rather fun to tape the dongle to an airplane window, plug it into my laptop, and watch our progress over the AZ/NV landscape, showing a credible speed ~575mph, and altitude ~35000 feet. I was surprised that the software didn't blow up, but it worked fine. Must have been outsourced.
Mike Halloran
Pembroke Pines, FL, USA
Location of routers is often derived by online services. The ISP typically knows the IP to Physical address table.
Raspberry Pi (or other micro with Ethernet, Arduino might be aiming too low) plus a cheap GPS such as the $20 NEO-6M, -7M, or similar. It'll have been done before, so design and code starting points should be available.
Attach (physically, wifi and power) an old smartphone to the router. It's easy to find a given smartphone over the 'net.
Use a router with other interfaces. Then the GPS module can be interfaced directly (not Ethernet).
https://wiki.openwrt.org/doc/howto/networked.gps
Beware GPS sensitivity. Good ones can easily work inside a house or some buildings. Others are deaf and need to be outside. The NEO family are quite sensitive, and cheap. Less than $20. There's one in my basement, running and 'locked on'.
