Wind Pressure On Wind Turbine Monopile
Dear Colleagues,
I would like to apply the wind pressure on the monopile of onshore wind turbine in abaqus. The wind pressure is governing based on the following formulae:
P= 0.025*ln(20z)*(ln(20z)+7), where z is the height of the monopile and in total is equal to 50 meters.
I have used the analytical field when applying pressure in abaqus and I have written the following equation:
(0.025*log10(20*(50-z ))*(log10(20*(50- z))+7)) with the magnitude of 1.
Please could you tell me whether this is correct?
Many thanks in advance.
Aryan
RE: Wind Pressure On Wind Turbine Monopile
How are you calculating the wind pressure in the blade "shadow" (up and downwind)?
