Standar or references for semi-trailer load capacity calculation
Dear collages,
Hello to everybody, this is the first post that I do in this section. I am a FEM analysit, and I have to develop the structural analysis of a semi-trailer. Which specification shall I have to use for the determination of load cases and the matnitud of that loads and/or impossed displacements?
Thank you very much for your attention.
3JC
3JC
RE: Standar or references for semi-trailer load capacity calculation
Cheers
Greg Locock
Thank you very much for your response. I don't know then if exists any specification about tests to perform on this type of structure for the homologation of the support. It will be vaid to try to reproduce them on finite element analysis.
Thank you. Regards,
3JC
Cheers
Greg Locock
Thank you very much for your response. But the problem is that in the country where I am emplaced, in Bolivia, there is no so much information about everything that you say, and costs are prohibitive. For these reasons I want to start the study by analyzing the structure with finite element analysis and comparing to actual standars.
3JC
Cheers
Greg Locock
