Wind on Elevated Walkways
I found a previous forum from 2014 that discussed wind on elevated structures, but I would like to re-open the topic. I am working on an elevated enclosed walkway with a rectangular cross section, and I am trying to determine the correct uplift forces. The walkway is elevated about 16 feet above grade. With it being open underneath, there will obviously be airflow both above and below the walkway. The previous forum seemed to suggest that the wind on the roof and the soffit underneath would both be going away from the structure effectively reducing the overall uplift on the walkway. But the more I look at this, the more I disagree because of Bernoulli. Bernoulli's principle basically says that as wind speeds up, its pressure reduces, and vice versa. Slower speed, higher pressure. As I apply that to my situation, because of the drag against the earth, the wind speed should be considerably less at 0'-0" than it is at 30'-0" where the roof of the walkway is located, resulting in a net upward force. Does anyone have any experience in such a situation or can point me toward a possible wind tunnel study that was performed? This seems like something that someone has to have done a study on. I just can't find anything. Thanks in advance for your help.
Brandon Buchner, PE
Brandon Buchner, PE
RE: Wind on Elevated Walkways
ZCP
www.phoenix-engineer.com
