Sheet Metal Help
Sheet Metal Help
I am trying to make a part from from my flat layout, the material is 6mm Lexan. I am using NX10.
I want to bend the 2 middle flanges up and the other flanges on both ends down, they both need to be inside the 12" tab I created.
Any help would be greatly appreciated!
Thank you
John
Thank you
John
RE: Sheet Metal Help
-Dave
NX 9, Teamcenter 10
Here is a screen shot of what I have.
Again I appreciate any help!
Thank you
John
-Dave
NX 9, Teamcenter 10
Got it figured out, got some help from GTAC as well!
I added regular flanges and then used the "bend taper" taper command to taper the flanges.
Many thanks!
John
-Dave
NX 9, Teamcenter 10
