Scale a sketch
Scale a sketch
Hi to all,
How can I scale a fully constrained sketch?
I´ve tried with Transform, but I can only create a copy of my sketch, with no associative lines, and without dimensions.
I´m using NX10.
Thanks in advance!
I´m using NX10.
Thanks in advance!
Airin
NX Designer
RE: Scale a sketch
RE: Scale a sketch
However, here is a work-around:
Create an extrude feature from your sketch; give it a start and end distance of zero. This will create a sheet body that you can use as input for the "scale body" command; the scale body command will create an associative feature. If/when you need to use the scaled curves as input for another feature, change the curve selection to "face edges" and select the scaled sheet body.
www.nxjournaling.com
RE: Scale a sketch
You can create a constant expression say s and set it to 1 ( s=1 )
now in the expression dialog change all the expressions that afect geometric sccaling
(angles are not) to (xxxx * s) where xxxx is the current expressions values.
after you do this.
your sketch is in scale 1 (s=1)
now change s to the value you need say s=2.125 and you sketch is scaled to 2.125.
RE: Scale a sketch
Airin
NX Designer
RE: Scale a sketch
Airin
NX Designer
