ASME Section VIII Division 2 Part 5- Terminologies and their actual physics
I have quite experience in solving design by analysis problems using ANSYS following ASME Section VIII Division 2 Part 5 rules. I know by practice some of the terminologies of the PART 5 and their physical phenomenon. But some terminologies and failure modes of the code I am yet to grasp fully. For example, following are the failure modes which I know partially and want to add more knowledge.
1)Shakedown-elastic and plastic
2)Ratcheting
I have sufficient knowledge of FEA. I have referred para 5.12 of code for the definition of the terms but as you all know, it is insufficient. I want to increase my knowledge and dig deeper about part 5 in general way (You can say Physics behind the Part 5 analyses, their requirements and requirement of setting of particular allowable stresses as well as loads for elastic plastic analysis) by using some reference books/papers/articles/guidebooks. Also most of the analysis involves material plasticity. Please suggest some good material for reference to start for Part 5 analyses (to understand actual physics behind the analysis and not the analysis examples) as well as some good reference material on material plasticity.
Thank you.
2)Ratcheting
Thank you.
RE: ASME Section VIII Division 2 Part 5- Terminologies and their actual physics
You can also search the various fora on eng-tips.com, too.
Would you please suggest anything in addition to above and references/books on material plasticity?
Thanks again for your recommendation and for your past posts on design by analysis problems in this forum. They are very valuable and cleared some doubts.
I will post specific questions as and when required. Thank you.
