SMAW - Single, Multiple Tandem, & Multiple Parallel Arcs
I have a weld procedure in front of me for a CJP field weld of a beam flange.
The procedure is approved for single arc welding only. I am a little bit confused by what a tandem arc is.
Two welders with seperate power sources. Welder A welds the top flange while Welder B welds the bottom flange simultaneously.
Is this a tandem arc, or is the two single arcs?
If the above example is single, then what is tandem and parallel?
Thank you
Thank you
RE: SMAW - Single, Multiple Tandem, & Multiple Parallel Arcs
http://www.thefabricator.com/article/automationrob...
Parallel arc welding is done with multiple separate arcs connected to the same power source.
Two separate welders with separate power sources.
