Welding Symbol (Intermittent welding)
Hi!
I wonder how I can interpret intermittent welding symbol, 3-5.
I think everybody agrees its welding length is 3 and its spacing is 5.
How about its exact locations?
In my opinion, all interpretations are correct.
(This means this notation method does not sometimes work.)
I am looking forward other opinions.
Thanks!
RE: Welding Symbol (Intermittent welding)
As far as I understand, a 2-6 weld could start with 2"weld--gap--2"weld--gap, etc. OR start with gap--2"weld--gap--2"weld, etc. OR maybe start with 1/2gap(at end only)--2"weld--gap--2"weld--gap--2"weld--1/2gap(at end only). Our QC manager agrees with that as well. Probably best left to the EOR to decide where s/he wants the weld to start and end, but I think a symbol "3-5" does not entirely answer the question.
For what it's worth, if the weld were stitched both sides and CL of weld increments were staggered, some of the confusion goes away because instead of Case A or Case B, you'd have Case A on one side but Case B on the other. I've not seen much single sided fillet welding, except where we make temporary attachments and the point then is to make it EASY to break the welded attachmemnt off with a hammer.
But who ever looks at AWS A2.4? When in doubt, throw in a sketch to clarify the intent. If you're on the other side, trying to interpret someone's weld symbol, you should ask them.
