Issue when opening Iges file from NX in Catia
I have a part with multiple surfaces. I sew all surfaces. Then export as IGES file. When i open the same iges file in Catia , the file has multiple surfaces instead of single surface. Any solution for this issue?
RE: Issue when opening Iges file from NX in Catia
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
Moving to NX10 with TC11.2
if not, why use Iges and not Step ?
In comparison, Iges is a very old translator which haven't been updated in recent years.
If you can use Step, you will most probably get better results than iges.
From wikipedia :
https://en.wikipedia.org/wiki/IGES :
"After the initial release of STEP (ISO 10303) in 1994, interest in further development of IGES declined, and Version 5.3 (1996) was the last published standard."
Tomas
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
