Fire figthing at Biogas plant
For a firefighting systema at a Biogas plant, do you have to include sprinklers at the reactor tanks? I believe not because once a fire starts and explosion would be inminent. And what you should do is design a ring with hydrants and water lines right?
RE: Fire figthing at Biogas plant
http://albanesmolina.wix.com/home
Assuming this is process plant scale, fire protection should be part of the overall safety case not just (or in addition to) any prescriptive code requirements. For example:
Matt
