Torsion or not?
Torsion or not?
I appreciate if you can tell me if the beam A (upper beam) causes torsion in beam B (lower beam)
Thank you
Thank you
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Torsion or not?
RE: Torsion or not?
RE: Torsion or not?
The lower beam (beam B) spans 15 feet between columns.
RE: Torsion or not?
RE: Torsion or not?
However, just ignore this torsion and run your load path assuming no torsion. We can redistribute this load because the beams and connections can deform a little and allow stiffer load paths to take more of their share of the load. This would only present a problem if you were dealing with a heavier load and thousands of load cycles (fatigue). Never really thought of steel "cracking" until I saw it with my own eyes.
RE: Torsion or not?
You mentioned, " if detailed correctly the no Torsion"
May I ask whats a correct detail for no torsion?
A sketch may help - Thank you very much
RE: Torsion or not?
If Beam B is free to rotate about its axis at the supporting columns, there will be no torsion as it will simply assume the slope of Beam A over its entire length. Such a connection would be unusual.
BA
RE: Torsion or not?
RE: Torsion or not?
RE: Torsion or not?
