Weld Assistant bead mirroring
been working with the Bead and Weld Point functionality in Weld Assistant for a while. In the weld point dialog box there is a option for mirroring (LH/RH variants), and that is great. But how to do with Beads? Is it really necessary to create unique LH/RH Bead features to get WLD-publications i each weld item?
