Gas turbines fuel gas valves seals resitant to high temperature
Hi , i m searching for high temperature (250degC) resistant fuel gas valve seals.
Fuel gas supply line of the gas Turbine is 6". There are main shut off, trip shut off and control valves. All have to fulfill tightness class A. Do you know any proven seals?
RE: Gas turbines fuel gas valves seals resitant to high temperature
The sensible strategy is to move the valves away from the heat. Can you do that?
Mike Halloran
Pembroke Pines, FL, USA
, and get a bit benefit from efficiency.
Valuable advice from a professor many years ago: First, design for graceful failure. Everything we build will eventually fail, so we must strive to avoid injuries or secondary damage when that failure occurs. Only then can practicality and economics be properly considered.
If YOU change THEIR gas line gaskets, THEY will probably void THEIR warranty very quickly.
Ga line seals are immediately a source of uncontrollable fires and flames.
