When calculating the Moment Bending
When calculating the Moment Bending Stress on a Pin, should the allow stress for a pin made from SA193B7 be taken from Sect.II-D, Table 3 or can a less conservative, larger percentage of the Max. Yield Strength be used?
Attached is a basic sketch of the closure bolting design.
RE: When calculating the Moment Bending
r6155
If this is a VIII-1 vessel (and by the way, would it be so hard to say what the design code is?), then review UG-35.2 along with App. FF if they apply to your situation.
