Solid works to dwg translation problem
Hi.....
I am modeling a roll in solid works and making a drawing of it and then i translate it into a DWG file. The problem is the hyperbolic profile of the roll is not getting translate properly, the point are shifting little bit here and there and hence when the dwg profile data is machined on CNC the roll is full of errors. Pls some one tell me the solution to get the exact profile in DWG format......
RE: Solid works to dwg translation problem
Eric
Anna Wood
SW2015 SP5, Windows 7 x64
My profile is a continuous curve and in dwg also it shows a tangent continues spline curve. I have seen that in dwg when i select the curve it shows two differnt curves, one is my profile curve it self and one is the curve connecting the vortex points of the curve. Second thing is when i first open the dwg file curve is not smooth and then if i double click any of the vortex point it becomes smooth. Whats the reason vehind it. I am done with comparing back my curve in sw but its not correct. Is there any thing by which i can give my solid model data directly from sw to machine?
Hello anna,
My cnc can interpret hyperbolic profile, thats no issue.
I am still not able to understand how it is possible, that some times my half profile or some length of profile is perfectly translated and some portion is getting errors.
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesGryphon Environmental
www.2gryphon.com
