Elevation change required at threshold to landing?
Situation is an entry door (swings in as usual) that opens to a covered landing. I know the threshold can't be higher than 1.5 inches, but then is an elevation change/step down required to the landing? Or can the floor continue at the same level?
RE: Elevation change required at threshold to landing?
Nearly all men can stand adversity, but if you want to test a man's character, give him power. Abraham Lincoln
