home dongle for V12
home dongle for V12
I used a so called home dongle (free dongle for home use as an extra for a licence in the office).
This worked fine with the V10 version but doesnot function with the V12 (I skipped V11)
I did copy the file "SElicence.dat" (with the dongle code) in the Solid Edge V12/Program directory
Wo can help me here?
Stan Smits
Stan Smits
RE: home dongle for V12
http://www.rainbow.com/
You can download the latest drivers. I had this issue when I loaded V12 a while ago. The computer couldn't find the hardware key. HTH
Jim
an update from V10 to V11 (or higher) the "old" hardware dongle can be used, only another software key is required (this is the SElicence.dat file!)
I received a new code and V12 is working fine!!
regards
Stan
Petr B.
