High Alloy Steel grade
Greetings to Respected and Experienced Members...
Please let me know this.
410 has less desirable properties than 316 but it is placed in High Alloy Grade category. What is the reason for this and what extra benefit they have because of this category.
Thanks in advance
Regards......
Hard Work with Smartness is the key to success
RE: High Alloy Steel grade
Because of the chromium content. The higher chromium is desirable in sulfidation environments and the chromium increases hardenabilty.
pdp123
Have you access to any basic book on Materials Science like Van Vlack, hope this is not an assignment question.
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
410 may have lower pitting resistance in aqueous chloride environments, but it is immune to chloride stress corrosion cracking.
There are also many high temp environments where the Mo in 316 is a detriment.
The alloys are very different, there is almost no application where these would both be options.
