Import coordinates in SDMS format into Auto Cad
I am attempting to write a VB app that will import survey design coordinates into acad. I have basicaly written the application I need to know how to convert from a comma or space delimeted format to an sdms ( each value occupies one line ) ex: pt no
north (y)
east (x)
elev (z)
descriptor
any help or reference would be great.
Tim
north (y)
east (x)
elev (z)
descriptor
Tim
RE: Import coordinates in SDMS format into Auto Cad
What do you want to do with the points?
A 3dpolyline?
What about PO NO and DESCRIPTOR?
Could you send a point-no.csv file and a sample of the drw you wnat to?
If so please do it to k281969@hotmail.com
Pardal
Tim
k281969@hotmail.com
Pardal
I'm waiting for your SMDS file sample, with out it I can not do nothing.
Pardal
I have a lisp routine that makes something like this.
It reads text file with point name x y z coordinates and inserts blocks with atributes
It works with separators (, . / and "single space")
If it will help I will send it to you
Zmei
I will send you what I did up today.
k281969@hotmail.com
Pardal
I have the routine that you need please sent here your email.
just sent them to Pardal!.
Zmei
I have a similar situation, I am looking to import a SDMS ali file into AutoCad. Did you get a way of reading the multiline SDMS format in VB? Any help would be appreciated.
Thanks.
Ben
I AM SORRY I HAVE TAKEN SO LONG AT GETTING BACK TO YOUR POST. TO BE HONEST I HAVENT REALY HAD ANY OPPORTUNITY TO CONTINUE MY PROGRAM IN VB. BUT I AM DEFINITLEY INTERESTED IN SEEING YOUR LISP ROUTINE.
TO ANSWER YOUR QUESTION BEN NO. WHAT I ENDED UP DOING WAS CREATING A BLOCK CALLED SURVEY POINT THEN INSERTING IT AT THE X,Y,AND Z COORDS AT THE COMMAND LINE. VERY TEDIOUS BUT I AM NOT DEALING WITH MORE THAN 10 POINTS AT A TIME.
As i think my routine will need some minor changes for the type of work you need, Please can you give me a little more details.
How exactly looks your SDMS file (I dont know what means SDMS :( ).
The curent routine can read coma space or any other user defined separator ( unfortunately no TAB) from the file looking like this:
Name,Xcoord,Ycoord,ZCoord
The other works with Excell2000
with cells in the same order.
Other versions of excell need to know what version you are using.
ZMEI
LINE 1 POINT NO.
LINE 2 X COORD
LINE 3 Y COORD
LINE 4 Z COORD
LINE 5 POINT DESCRIPTOR ( OPTIONAL )
EXAMPLE:
1
1500.00
2500.00
125.00
I GUESS THE PROBLEM I AM HAVING IS FIGURING OUT THE COMMAND TO MAKE ACAD TAKE EACH LINE AND MAKE A SINGLE LINE WITH ALL 5 VALUES BEFORE IT INSERTS THE POINT. IF I FIGURE THAT PART OUT THEN I CAN JUST LINK IT TO A LISP OR VBA ROUTINE THAT READS AN ASCII FILE AND INSERT MY SURVEY BLOCK.
Your routine is ready.
Just tell me where to send it.
Zmei
Zmei
I hate to say this but like a doofus I managed to delete all of my in box before I opened your file.Could you send it again.
Thanks Tim
