Press fit hole for ISO m6 dowel
I need to press fit a 6mm diameter dowel pin into a part. The pin is ISO m6 (+4,+12)µm. Should I use a M6 ISO hole (-1,-9)µm? So many options...
RE: Press fit hole for ISO m6 dowel
Look at the limits and fits in your Machinery's Handbook. FN1?
JHG
Or is disassembly for repair a possibility.
Appropriate fit for SST into MIC-6 aluminum may be different from appropriate fit for high grade steel into high grade steel.
Just saying.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
