Repetitive Datum callout
If the part is complex shape drawing is more than one sheet, Datum’s can be called out more than once to make it clearer. When calling same datum in other view should have “Ref” under datum callout?. I have drawing in which Datum A is called out with Flatness in view. In other Just Datum A is called out same surface.
RE: Repetitive Datum callout
Datum feature still datum feature.
