Static analysis convergence issue
I am working on substructure analysis of pick up truck given in abaqus example problems manual 3.2.2.I am trying to run a static step but due to non linearity the solution is not converging. It is supposed to be a one increment step, but that is not the case when I run the simulation. Any help would be appreciated.
Thank you
Thank you
